matt reid
Do all Yanmars overheat? It seems anytime I motor my Yanmar over about 2600rpm the thing wants to overheat.Ive been thru the whole system from fresh water intake to exhaust(shy of taking the heat exchanger off) and havnt found a reason for the overheating. The Yanmar manual does list overpower as a possible reason for overheating. It has the proper salt water sensor and thermostat. Have checked raw pump/impeller etc. It seems to be no problem if I keep the rpms at 2500 or less. The boat is a 1988 H 37.5 and the engine has approximatly 600 hours on it. Any suggestions? thanks
