Yanmar Oil Additive
Bob Rutland
Has anyone ever tried any of those "as seen on T.V." oil additives (Slick 50 etc.)in your Yanmar. If so, did it work or was it just a waste.
K
Ken Palmer
Never tried it, never will
You are sure to get an overwhelming response from others that you shouldn't use any additives. Yanmar doesn't even recommend synthetic oil. Ken Palmer, S/V Liberty
Duane Nifong
Often Wondered the same thing
I've talked to some marine mechanics that told me Slick 50 was good for my engine. Then others have said "No Way, just use a top grade oil" At this point I'm only going to use what the factory says..
Michael Cohn
Snake Oil
Consumer Reports has studied these various additives and found them to be of no value. I think at least one of the companies making them got in trouble with the FTC for false advertising. MC
Bob Blackmann
If It Ain't Broke.....
If it ain't broke......don't fix it!! Stick with a premium motor oil. Bob
Sam Lust
Additives
If you are using an oil with a brand name you recognizeyou have absolutely no need for additives of any sort. Name brand oils meet or exceed SAE standards. Yanmar is finicky about what goes into the engines and recommends against additives.
Ron Hughes
Additives? What about their coolant additive?
We went to a Hunter rendezvous last summer and the Yanmar guys who gave a seminar there said we all should buy Yanmar coolant, do any of you have any info on this issue? What's different. Ron
Jay Hill
More on Oil Additives
Not long ago I got the technical explanation of why and why not to use additives so I thought I'd share it. Additives can, in fact, extend the life of an engine IF THE ADDITIVE IS USED WHEN THE ENGINE IS NEW. When the engine rolls off the factory floor (when you buy it new) an additive is fine because no grooves or flex exists in the motor. The additive (usually teflon-based), coats all the parts and keeps them from rubbing the grooves into the cylinder walls, on the crankshaft, etc. for about 75,000 miles or 1,500 hours. On the other hand, the life of the teflon is based on the compression ratio in the engine. With a gasoline engine running approximately 7-9:1, the teflon lasts about 20,000 miles where more can be added if desired. With diesel engines running compressions ratios of 17-28:1, the teflon is broken down under pressure and lasts on 2,000 or less than 50 hours meaning you would have to completely replace it roughly once per month to make it do anything: Very Expensive. If your engine is used (more than 10,000 miles or 100 hours), the grooves and flex already exist and placing a teflon-based additive to the engine causes the additive to settle in the grooves and flex. This deforms the "natural" operating environment for moving parts (cylinders, crankshaft, etc.) and actually causes the engine to work harder to produce the same horsepower which means a higher operating temperature. The guy went on to explain viscosity and the exact temperature and pressure combination where teflon is broken down into nothingness, but I got the message early and didn't remember any of that stuff. So, don't use an additive in a diesel, ever.
