Yanmar instrument panel
Feb 28, 2006
81
Hunter 34 610 Narragansett Bay
Instrument panel was damaged and am now looking to replace the plastic face plate only. Old Port in Newport, RI has the B version except it doesn't have the "pull cable to kill the engine". Do other Hunter 34 owners have the pull cable located in another location or is it supposed to be on the panel and I only have to drill the face plate to accept the cable? Thank you, Randy
Dec 2, 1999
15,184
1. Have you checked with Mack Boring?
2. Have you considered relocating your fuel cut off to another location. The cut off is what usually destroys the face plate.
Nov 22, 2011
1,261
Ericson 26-2 San Pedro, CA
I managed to get the plastic face plate for mine from Boatswain's Locker in Newport Beach, CA (phone 949-642-6800). I think mine might be the same as yours. If so, it is part number 128170-91010. If not, I suspect they would have whichever one it is that you need. For me the cost was $28.51, purchased a little over a year ago.
Dec 2, 1999
15,184
Yanmar Marine has geographical territories, so he would not be able to purchase one from a West Coast Distributor/Dealer.
Feb 28, 2006
81
I checked with Mack Boring and Torrenson. MB referred me to Old Port and Torrenson no longer ships parts. Steve, I agree with you on the reason the plate gets damaged. Poor location for the kill cable to be protruding out like that. I was hoping other 34 owners might give me an idea where their fuel cut-off is mounted, if not on the panel. Thanks, Randy
Jul 28, 2013
126
Hunter 34 Holland, Mi
People have said they mount the shut off cable in the fiberglass next to the panel.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
I re-mounted mine on the fiberglass to the left of the panel as you face it. Much better as it is about 1/4 in thick. I used a couple of large ss fender washers -one inside and one outside-and 4200 bedding compound to seal it. Much better
