When I purchased the 1986 40' Hunter in the fall, I noticed the panel (type b panel) was loose, the cover was cracked and loose but thought nothing of it. Its probably been that way for years - I did weekly starts of the motor over the winter and had a few strange happenings, but could not pin point it to one thing. We had some heavy rain in the last few weeks.
Two days ago, I went to start the engine and the alarms were working, but the engine did not have enough power to turn over completely (tried and died). I checked the battery - all good and tried again. Still no luck. I had other maintenance - did a few jobs and then I left it to try/check next day.
I did notice my charger had stopped working ( coincidence?)-reset it
Yesterday I was back doing more jobs, I tried the engine one more time to try and track the situation. This time the engine tried to start. The starter was turning, and would not stop, even after the key was returned to the off position. May have burned out the starter. Once again, worked on other jobs, and then home to go on-line to do some research.
Today when I went back, I tried the engine and the alarms are no longer sounding, no lights, nothing. Once again the charger is not working - will not reset.
Anyone got an idea - could it be the panel/starter switch is shorting out - moisture or corrosion?
