Ok, Thanks, I think
Thank you all for your input so far, but I am just asking if anyone has one of these for a YSM that they want to get rid of. If these engines are in good working order they are easy to start with the hand crank, I started both YSM8 and 12 with no problems. The YSM engine, both the YSM8 and the YSM12 is actually very easy to start with the hand crank as it is a singel cylinder engine. The trick is to get it spinning as fast as you can and once the decompression lever is released, FOLLOW THROUGH the compression strokes, keep cranking as hard as you can till it starts. The hand crank shaft is on a rachet system so if it starts the shaft will free wheel as to not hurt you at all. That is why you can grab that shaft when it is running, it is spinning slowly or not at all because it is free wheeling. If you don't follow through when the decomp lever is released nothing is going to happen. It will just stop from the compression. The shear weight of the flywheel will help you pull the engine through the cycles. So, Since these engines came with a hand crank that work very well, and since mine is missing: Does anyone have one that they want to get rid of? or still have one left over from when they re-powered? I'll buy it off ya.Thanks again,Dave
