Hello folks,
if you can help me-thanks so much. I have a Hunter 356 2002 model. I am in the middle of a grand summer sailing the Great Lakes. Well sort of....! The boat is quite new to me and so after 10 days of trouble free sailing-I decided to change the fuel filters [probably had not been changed in 10 years]. Anyway I did that and then followed the manual to prime [bleed] the system to purge air. I noticed right off that the priming lever does absolutely nothing! Regardless for the next 3 hours I pumped it over 300 times and the engine still will not start. I realize it is not getting fuel. I am a technical guy [former automotive engineer]. The tank has plenty of fuel. There is simply no fuel emitting from the either filter bleed hole during priming attempts. It is Sunday and Yanmar technical help is not available. Do you have any suggestions to purge the air from the fuel system.
thanks so much.
Jim Mongene in Charlevoix, MI
thanks so much.
