Yanmar exhaust hose
Dec 28, 2015
39
O'DAY 322 Bridgeport CT
I am trying to replace the 1 7/8" exhaust hose on my 2gm20F but cannot seem to get it over the exhaust elbow fitting. I have heated and greased it and struggled with it over the week end.
Is there some trick to stretching the hose enough to get it over the fitting?
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
you need a 2 inch hose not 1 and 7/8
May 24, 2004
7,174
CC 30 South Florida
I was going to say if it does not fit you have the wrong size hose. Were there any markings on the removed hose indicating the size. I have in the past encountered the need for a hose of different sizes at each end and would likely not have known had I not happened to inspect the old hose.
Dec 28, 2015
39
The original hose was clearly marked 1 7/8" and the distal end fits the muffler just fine. Really don't want to remove the elbow to make it easier to fit the hose.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i don't think you are going to put a 1- 7/8 inch hose on a 2"fitting with any great success...you are going to have to find an adaptor that will take a 1 7/8" hose on one end and a 2" on the other end.....and also purchase a section of 2" hose and 4 more hose clamps granted you have enough room in the run to do it at all ....other solution is new 2" hose and a muffler that has 2" exhaust in and a 1- 7/8 out
Dec 28, 2015
39
Woodster; Do you have info that the 2GM20F has a 2" outlet at the elbow? I did not measure the outlet but I took a 1 7/8" hose off the same fitting.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
they are 2" and they always have recommended that size in every thing i have read overthe years
