yanmar engine water seperator
14
- - NYC
Sailors, Just had an intersting conversation with the mechanic fixing my engine. He has by passed raco water seperator and said i don't need it and the engine is 100%. Is this true? Also where can i get a new raco water seperator and at what price? Is this something i could install myself. please advise.
Jun 6, 2006
6,990
Every diesel needs a water sprerator
All diesel engines need a water separator. They are usually part of the primary fuel filter. If you have a primary fuel filter with a screw on the bottom where you can let the accumulated water out then you don't really need a device who's primary purpose is to separate out water as the fuel filter will be sufficient.
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Depending on size of engine . . . .
It looks like from a previous post of yours, you have a Yanmar single cylinder (?). If so, a Racor 110 or 120 will do just fine w/ a 30 micron element. These can be bought from Defender for ~ $100. Is the one bypassed still there? Which model? You may just be able to replace the element for $10 - 20 if the housing was left in the fuel circuit.
