yanmar engine warning lights
John
Does anyone know how to change the bulbs in the three red warning lights on my 1999 340 Yanmar engine start/ignition panel.which is mounted on the port side of the steering pedestal. Thanks all
Paul Akers
Behind the Panel
John, there are 4 corner screws on the black portion of the panel. You should be able to remove them to gain accesss to the bulbs that you are questioning.
Miles
Or...
The center insert in the pedestal lifts out. There is access in there to the back of the panel but I can't remember how easy the bulbs are to reach. Pulling the panel off is the sure way but you might be able to just reach inside too.
