Yanmar decal
Aug 3, 2014
65
Beneteau 343 San Francisco Bay
This is revisited I'm afraid, but over the years, maybe some real resolution has arrived. My Beneteau 343 with Yanmar 3YM30 engine has Fig. 34, Instrument Panel B-Type/Optional. (Just FYI, there is a plastic fitting between the ignition-switch body and the panel, which may or may not be molded into the panel itself. Mine broke and I've spent endless hours trying to replace it. At this point, it's obvious that there is NO replacement, so I've made my own "washers" out of plastic. Even thought of trying to design and plastics-print a new one, but there are too many facets to that washer. As a matter of fact, the plastic nut on the outside, which holds the switch to the panel, has NO replacement, and since the switch and the nut have square-cut threads, it became impossible [for me] to even replace it).
Anyway, does anyone have a source for just the decal that goes on the panel? All the corners and edges of mine are peeling. I've seen comments about going to a printer and having one made, etc., but I just want to buy a replacement OEM-type decal. Possible? Thanks.
