Is it common to see oily discharge water from the cooling discharge on stern? It seems that there is a greyish colour in the water, I am making an assumption it is likely oil. Do I need to be concerned?
cheers
Willy
thank you all for your quick replies... I took a water sample of the discharge, and they re particles and have concluded it is carbon .... I have been told that carbon is common in diesels.. and what I have is a carbon build up.. that needs to run at 80% to max RPM for 30 - 45 min .. i have also read in the manual that the engine needs to cool down before shut down and therefore I should run it at low RPM for five minutes and then rev up to max RPM and then shut down immediately..
I do not think I have a problem other than carbon build up... thank you all
cheers
Willy
