my 3gmf yanmar engine is overheating. just replaced the raw water cooling pump , plenty of flow out of the pipe. my coolant in my manifold is dissapearing, after fifteen minutes of run time. engine starts great and sounds great. my water heater heat exchanger seems ok , no anti freeze in the hot water outlets. then when the coolant is gone i overheat. what is going on. where is the co ollant going? i do not see a film on the water where the raw water pump discharges. ???? i am in fresh water but the boat came from salt water, three years ago. any ideas.
