After much debating as to putting a foam element back in my 3YM30 air filter housing after being without for a year I've decided filtration is important even out on the wild blue.
So, instead of the foam element I've gone to a K&N air filter that fits perfectly on the 3YM30's 1 3/4" intake. I do not have to worry about the foam breaking down, I will probably never have to clean it, it enables the engine to breath better, and it looks less cluttered in the engine compartment.
All I did was cut a 4" SS tube of 1 3/4" OD and 1/16" thickness to attach to both the original rubber tube and the rubber tube on the air filter. FYI...see below info.
Breathing easier now!
K&N air filter RE-0260 - Universal Rubber Filter
http://www.knfilters.com/search/product.aspx?prod=re-0260
