Starting Fluid
I want to begin by saying Fred's response is right on target, recommend you follow his guidance, if you are not sure you might want to replace your diesel fuel, replace with #1 diesel if you can get it. Most probably Fred is right. I manage contracts for the Army . We rebuild and dyano about 700 - 1k diesel engines each year, all sizes/types. The number one cause of bent rods and blown heads is lack of PM/ preventive maintenance thus resulting in the use of starting fluid which reslults in the above. If you don't bend the rod from excessive chamber pressure from the too much starting fluid it will when the head gasket blows and water leaks into the cylinder chamber, water will not compress so the rod bends. The only time we use starting fluid is for recovery of vehicle from a field enviroment that has problems we cannot fix on site and only highly trained personnel are allowed to use the fluid or in emergency situations. If regular preventive maintenance schedules are followed and fix the problems as they occur without using additives such as starting fluid it will be alot less expensive in the long run. Replace those injectors and head gaskets if necessary, replace that fuel filter,etc's its cheaper than a whole engine rebuild or worse replacement. If you don't have a service manuel recommend you get one from yanmar you won't regret it! I my busines starting fluid cost millions of dollars, amazing how much damage a cheap can of fluid can do. Good luck and Merry Christmas! Jim
