Yanmar 3YM30 Oil pressure sender threads
Sep 20, 2006
2,952
Would anyone know the threads for the oil pressure sender. I was looking at the ACDC Marine Oil dual pressure / alarm sender and can't find the thread sizing. ( boats 3 hours away under snow ). I know the water temp is M16 and assumed oil would be M10, but getting conflicting ideas.
Apr 8, 2011
774
Hunter 40 Deale, MD
Write directly to ACDC. They're very knowledgeable and know what threads your sensors are, and what adaptors might be required. They'll need the year, model and make of your auxiliary. I'd deal directly with them - if they make the wrong call they'll swap out the gear. If you make the wrong call based on internet advice...
Sep 20, 2006
2,952
I tried email and msg on Faceboook over a week ago. I'll give them a call. Wanted to confirm if I could elsewhere.
Likes: tfox2069
Apr 8, 2011
774
Hunter 40 Deale, MD
I was able to talk directly to the owner via phone, and he was very knowledgeable. Good luck.
Sep 20, 2006
2,952
Just talked with ACDC. He at first said the 1/8 BSP thread would work, bu that the M10 is better. They have a 80 psi pressure sender and alarm switch. Also have a 0-80 psi gauge with alarm built in.
Likes: tfox2069
