This came up on another forum, but the guy never got an answer. On the bottom right side of the oil pan (looking from aft to forward), there is a bolt with a large head (>19mm) which I believe to be an oil drain plug. It is not in the Yanmar diagrams as far as I can tell. Anyway, I have 12+ cm of room under there, can get a pan in, a socket wrench on it, and would like to drain my oil that way, rather than the through-the-dipstick suction method. This is on a 2006 Beneteau 343. Has anybody changed oil via that plug? BTW, I've looked at all the 12v pumps, manual pumps, etc., and will go that way if the "drain bolt" isn't bound to work. Thanks.
