Recently purchase a 2007 Hunter 31. Not sure how old the coolant is. Would like to replace the coolant with fresh for winter layup. My Yanmar operator's manual shows 2 drain locations for the fresh water system. One on the side with the fuel pump and oil filter that looks like a plug screwed into the block and one on the port side on the hose that comes from the fresh water pump that has a slot on the bottom that I expect is a threaded plug. Are there any other drains I need to open to drain the coolant out of the fresh water cooling system. I would also empty and clean the plastic overflow tank. Any tips to keep from making a mess of it.
