Walt is correct
It seems to me that there is one inside the cast cover on the end of the head, in addition to the one he mentioned.The manual is a good thing to have, as well as the parts book. If you travel, say to the Bahamas, it's one of those "Don't leave home without it" deals.Seems to me that the heat exchanger also has one. It's an aftermarket item, so the manual won't cover it. Call Sendure (I think that is the spelling) to ask them. In the event you need a new heat exchanger, (Ours are all getting old)they can make one for you, cost is around $200 if you get it through Boat US special order. You can have a bigger, custom size one made (I did) to allow for blockage and other overheat problems. The extra cost over standard size is negligable.
