Jared
The engine on our 1987 Hunter 34 - 24hp Yanmar 3GMF - has a difficult time starting if it hasn't been used in a couple of days. Once she runs for a while and then we sail for a while and then go to fire it back up, it will start right up really smoothly. Basically, for the first start, I have to hold in the start button for 10 seconds or so with 1/2-2/3 throttle and it starts kind of choking a little bit for about 5 seconds plus and then revs up smoothly and I then throttle it back down to idle. A bit of smoke comes out of the exhaust during this time as well - mostly white smoke, but the first time I did this I was chicken to hold the start button that long and after about 4 tries, some black smoke came out of the exhaust. I have pretty much only started the engine when the air temps. have been around 60-70 degrees F.Being that I am new to inboards (had a 25 footer with an outboard until a month ago), I am not sure if this is normal or not. Is it? If not, where should I look first? During the survey, the fuel filter looked clean and I have a full tank of deisel. Also, anyone know of a book like "Deisel for Dummies" or something so that I can learn what I need to know?Thanks.
