I have always been careful to shut down the engine whenever I would get and over temp alarm. As some readers will know, this problem has continued for an eternity.
I was exasperated. Performed every test known to Yanmar and the common man. At one point even suspected a leaky head gasket. Also had been through mixing elbow, seawater impeller, input clog check, crimped hose check, temp alarm check, heat exchanger cleaned, radiator cap replaced, thermostat replaced, etc, you name it.
The problem was simply a slipping pulley on the seawater pump. The pulley nut was tight, but at high RPMs, pulley was not turning the pump at full speed.
The key on pulley had worn and ground a groove into the pump shaft.
This week I had been running the engine at a safe 2200rpm when the overheat alarm went off. Since the problem had never occurred below 2700 rpm, I knew there had to be a new source. Went to check the seawater impeller, and found that the pulley was the culprit. At low rpms it had worked quite normally. At high rpms.. it would slip just a little to reduce cooling efficiency. Who would have thought it!!!
Had to replace the whole pump.. ouch. Just finished cruising for 2 days, often at high speed, and no move over temp alarm.
