Yanmar 3GMF oil change
nemo99
Jan 23, 2009
2
2 37 Santa Rosalia Mx
Hi; I have a yanmar 3gmf and change oil in the engine by inserting a small tube into the dipstick hole and pumping the oil out. The problem is I can't seem to get the tube down far enough to get more than about 2 or 2 1/2 litres of old oil out. The tube I'm inserting seems to hit something and will not go all the way to the bottom of the oil pan. Solution anyone? Thanks.
Nov 6, 2006
10,057
Nemo, I have the same engine and you are probably hitting the bottom of the oil pan. Problem is that unless you can get the tube to bend to go to the aft end of the pan, ya can’t get all the oil out since the engine is slanted down aft.. This winter, I had removing the pan and installing a low point drain on my list, but haven’t gotten there yet. Many engines have a tube that the dipstick goes into that works as an effective guide for the oil removal tube, but this engine does not have the internal guide tube and the oil removal tube can go all over the place in there if it is flexible!
7,349
Alden 50 Sarasota, Florida
One trick I learned is to mark the tube at the same length as the dipstick so you can see when the tube is close to bottom of the pan.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
kloudie1
I did exactly that at the end of my first season with the boat. I removed the oil pan and installed a drain petcock at the back of the pan. Oil changes are a breeze and I get every drop of oil out.
Nov 6, 2006
10,057
Outstanding, Alan.. It has taken 18 years for it to tick me off enough to do it.. I bought the valve and plug a couple of weeks ago ..
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Kloudie & Alan, what size petcock? "Purest" might say that having a piece sticking out like that could be broken off too easily; but it is real tempting. Metric? NPT?
Aug 19, 2004
239
Hunter 35 Vancouver, BC
Take a look at this recent thread http://forums.hunter.sailboatowners.com/showthread.php?t=103918 and you will see a picture of what your tube is hitting and a solution to your problem.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Andy
You can use any thread fitting you like, NPT, Metric...so long as you match the tap to the fitting thread. Removing the pan is simple after you've sucked out the oil for the last time. Remove the 6mm bolts that hold the pan in place and drill a hole at the back of the oil pan then tap it. You can use a drain plug or a petcock. I opted to use a petcock so that I don't need tools and the petcock doesn't need to be removed. I then slide a one gallon anti freeze jug laying on its side with a cutout under the engine and open the petcock. You could also use a disposable aluminum baking pan to catch the oil.
I couldn't foresee anything damaging or breaking either a petcock or a drain plug. There is absolutely nothing under there to do any damage.
For the life of me I just can't understand why anyone would want to go through the hassle and mess of extracting waste oil when gravity will do the job so much easier and completely.
