Brent Lewis
Just purchased 85 H34 boat and doing maintance on engine I drained coolant on fresh water system on Yanmar 3GMF and was going to flush sytem and replace with red anti freeze as recomended for longer life of coolant. I drained block at both drain ports and disconected hoses to hot water heater and just installed loop as I am replacing hoses as well. Drained out aproxx 1 1/2 gallons of old coolant and what looked like mud.Spec say capacity is 3.4 liter. Problem is when filling back up at heat exchanger could only get it to accept maybe 2 liters at the most. I drained a little more out of the block to make sure the block had water in it and then started engine thinking that once the pump started it would take more. Level remained full at filler. waited thinking once engine came up to temp thermostat would open and take remaining water. High temp alarm came on before water level ever went down. With infra red thermometer took reading at stat housing and showed 175- 185 well above where stat should be open. Thinking stat was slow I replaced with new and same situation. Even tested both stats in pan on stove and both started to open slowly at 71 c and fully open at 85c like specs say, one was more slow then the other thoughthinking there was something else I dove into system taking apart heat-x,water pump and removing all hoses which I planed on replacing anyways and never really found anything that I belive could be causing any problems other then a worn area on back plate of water pump that a previous impeller wore a goove that I am going to have built back up and some build up of mineral next to the seat of the bypass passage.Am I missing something ?Is this common for the alarm to go off while refilling the cooling system.Yanmar service manual doesnt address any special filling requirments.Has anyone else expiereinced this problem ? I am awaiting gaskets and hoses now before I reassemble.Think I will replace water pump as well while I have system apart. Any advice or expierience would be apreciated.
