Yanmar 3gm30f - heavy vibration/shaking in neutral
jpeac2
Feb 9, 2007
31
Beneteau Oceanis 351 Belmont Harbor
Hey Everyone -
otor has been running great but this morning something new developed and not sure what to make of it as I am in no way a diesel motor expert.
Motor runs with no issues in gear but in neutral it has a heavy vibration / shaking that I have not had previously.
3000 hours.
Going to hop in with goggles to take a look but thought I would see what folks here think.
Any thoughts?
Jan 4, 2006
7,261
Just make sure you're not wearing a tie.
Usually the problem works the other way around. Smooth in neutral and heebie jeebies in gear.
Other really remote maybes to check while you're down there :
- shaft coupling is tight.
- broken mount as per @Don S/V ILLusion
- place your hand on the x-mission and other parts to see if that's the source of vibration or knocking. Watch that neck tie !
- check all V belts for tension (I said this would be remote)
- check alternator, water pump for mount tightness.
- remove the main V belt and check if the crank bearing is tight.
- and that's about it, as this is so unusual.
Maybe never put the engine in neutral again ? Turn the engine OFF when you want to slow down as you come into your slip ?
10,093
Try engaging one decompression lever at a time.. only one then back on then the next one etc. you may have one cylinder that is not working as well as the others. Could be a too tight valve or an injector not up to snuff. If the valve clearance has not been checked, that might be a good place to start.. good luck
Nov 21, 2007
673
After changing the fuel filter on both my Yanmar and my John Deere compact tractor (also Yanmar), I have experienced rough running at idle until small amounts of trapped air are completely purged. Check for fuel and air leaks while you're in there. Use an old tie...
  • Helpful
