Yanmar 3GM30F cold start procedure
30
Beneteau Oceanis 40CC Vancouver
I know there've been posts on the issue of cold starting of Diesel engines before. One thing where you see all kinds of proposals is throttle position. What's the general wisdom here ?
Andreas
Dec 19, 2006
5,813
Hunter 36 Punta Gorda
Wow
It must be still pretty cold up by you I guess,I don't do much cold starting much any more but when up in NY I would put the throttle half way and than start.
If it's really cold some sort of heat like maybe a heat lamp in the engine compartment would be a good idea.
Nick
Feb 2, 2006
470
Hunter Legend 35 Kingston
I usually give it at least 3/4 throttle, and keep my hand on it so I can quickly move it back to a good "warm up" position once it fires up.
If it's been run within the last 1-3 hours, it sometimes starts with the throttle at idle.
Jun 19, 2004
512
Catalina 387 Hull # 24 Port Charlotte, Florida
I have the 3JH3E. When it gets cold here, rare although it does happen, I have a glow plug position on the ignition key switch. It is spring loaded, so I just turn the key to the full on position and hold it there about 15 to 20 seconds, release and hit the starter button. It always fires and I roll the throttle up to about 1400 in neutral until engine comes up to operating temp. Never had a problem with it, and have used this technique in the mid 20's.
Oct 14, 2005
2,191
Throttle positon when starting...
on my 3GM30F I usually set my throttle to about 1/4 to 1/3 and flip two of the three decompression levers to lessen the load on the starter. Once the engine turns over and one cylinder fires, the levers reset themselves and the engine spins up.
In cold environments I've read that some use a hand-held hair dryer aimed at the air intake horn as these engines don't have glow plugs to heat things up to make cold weather starting easier.
galynd
Nov 1, 2009
170
Beneteau 36cc port arthur, tx
my 3gmd manual says to give it full throttle. I do this and bring it back to idle very swiftly. I had problems starting in cold weather until I learned this. No problems since.
Jun 7, 2007
515
Hunter 320 Williamsburg
A gentler method...
On my 18 2GMF I use a hairdryer with a PVC elbow to warm up through the air horn for ten minutes. Then I start with the throttle slightly open, not fully. Works wonderfuly.
By the way, if you haven't operated the engine within 48 hours and it's cold, Yanmar suggests holding the kill throttle out and "start" for ten seconds, twice. This coats the cylinders with oil more favorably.
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
As we know diesel engines need heat in the cylinders to ignite/start. Turning the engine over for about 10-15 seconds puts heat into the engine. Let the engine soak in the heat by waiting some seconds before turning it over again. Heat is what a cold engine needs to start. By setting the throttle to a faster position the engine's compression is set higher creating more pressure and heat. As engines get older compression is lowered, which means getting heat into the cylinder for ignition may take longer. Try different throttle positions for your engine. Engines are all different due to their age and condition.
Oct 2, 2008
30
Thanks
Thanks to all of you for the advice. Still seems to be very individual ... We find all preferences from 1/4 to full throttle.
Dan: the proposal with opening 2 decompression levers is an interesting one, will try next time.
Andreas
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
By setting the throttle to a faster position the engine's compression is set higher creating more pressure and heat..
Really? How does setting the throttle higher increase compression?
druid
Dec 2, 1999
15,184
Paul: Someone explained that increasing the throttle advances the timing. I doubt that it increases the compression.
Paul F
Jun 3, 2004
827
According to the service manual's cold start procedure "When the control lever is set to the HIGH SPEED position, injection timing is automatically delayed to facilitate starting." This allows the air/fuel mixture to become more compressed and create more heat before ignition. Not an engineer here, just thinking it through.
3,431
Seidelman S37 Slidell, La.
Throttle position
I have a 3GM, and when it is warm in the summer it cranks right up, with the throttle at idle position. As temps cool off, takes more throttle. When the temp is around 50 or so, it starts best with full throttle for a few revolutions, then pull back towards idle. Usually fires right off, when the throttle is about 1/4. If the temp gets into the 30's, or lower, it can be a bear, and requires lots of full throttle. Fortunately,don't get much 30 degree weather here.
druid
Apr 22, 2009
837
Hmmm.... First of all, "air-fuel mixture" is a gas-engine term: in a diesel, the AIR is compressed, then diesel is injected, supposedly almost instantaneously vapourized, and burns. Now, in a starting engine I'm guessing the problem is the fuel isn't vapourizing before burning, creating the blue or black smoke. (Anyone who's started a Dickenson diesel stove would know what I mean!). Now, assuming the injection normally starts before TDC, delaying it would mean it would be injected closer to TDC so the air would be more compressed before the fuel enters, which I guess would mean it's more likely to be vapourized before it starts burning.
But unlike a gas engine, the throttle setting on a diesel does not vary the amount of air in the cylinder, so therefore does not affect how much compression there is.
druid - amused that we still call it a "throttle"
