Yanmar 35 Hp Engine Owners Manual
Jul 22, 2020
48
Hunter Legend 37.5 37.5 New Braunfels
I need to replace my impeller and I was looking thru my prior owners manuals that he left on board for a part number for this impeller and the chapter on the Engine Owners Manual was missing (naturally). Where can I get his chapter?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Find your engine manual below for a Yanmar 3HM35F.
48
Thankyou Sail sfbay…..I appreciate your promptness. My engine is a 3JH 2E. Do you think this manual is for that, as well, because I do not see any notation for 3JH anywhere on it. Am I missing something?
Feb 21, 2013
4,638
Find it on these links.
Dec 18, 2012
160
Hunter 37.5 Annapolis
Panama Jack,
I have loaded a PDF of the manual below. Although I don't see anything on the impeller :(
Replacing the impeller is straight forward, except the bit about pulling the impeller out. I've found a pair of these to be seriously helpful.
Paul
48
Thanks PAC. That was an interesting manual. I had not seen that one. I found another that a Hunter member sent me a link to and it was detailed very nicely and was 309 pages long. I printed out what I needed.
Yeah...it was a bugger getting out. I used a screw driver and then pulled out the intake hose to try and get behind the impeller with a screwdriver. Plus you have to remember, the impeller does not come straight horizontally out. It is actually at an angle downward slightly. But I got a new one and replaced it. It was even harder to put the new one in. Had to use a zip tie to squeeze the blades enough to insert it into the housing. But I did it.
Ever been to the Annapolis Yacht Club...they have great mussels.....
Thanks again.
