You'll wear out before it will
THe 2qm15 is a very rugged engine designed to run under salt water conditions. If you change the oil and filters reguarly, and maintain as the book says to do, it will last at least 4-5,000 hrs., and then can be rebuilt if needed. Most of use don't use our engines 100 hours/year, so most engines die from either losing the water pump impeller and thus cooling flow, water in the oil, or some other lack of maintenance related item. BUy the book, observe the maintenance intervals, run the engine at least once a week if possible, and it will last as long as you need it to unless it was previously abused. By the way, max rpm on the 2qm-15 is 3000rpm, not 3600 as the 2gm series in the later hunters. Many of the parts are the same, but you should cruise at 24-2700 rpm with the 2qm unless you are in an emergency situation and need the power for a short while.
