Yanmar 2gmF zinc(s)
Feb 6, 2013
437
Hunter 31 Deale, MD
The Yanmar service manual indicates the use of zincs on a raw water cooled engine. The 2gmf uses a heat exchanger so the raw water only passes through the heat exchanger.
1) I assume that means the engine uses plugs in place of zincs.
2) Shouldn't there be a zinc on the heat exchanger? there is none show in the manual.
Thanks.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i have had mine all apart and couldn't find any at all and there have been several threads on here about this and it always comes up none on the f model
Nov 6, 2006
10,108
No zincs.. Exchanger is made of components that are not very prone to electrolysis.
