F
Frank Brdimus
I drained my engine's coolant and replace it with a fresh solution (40% anti-freeze). My problem is that the engine now over heats after 10 minutes on idle. My next move was to replace the thermostat but that did not help.What should be my next move - flush the stystem and use a cleaner. If so what what cleaner should be used??Other suggestions????????
