quick question ~ I have a 95' yanmar2gm20f that has new newly installed into my 91' Hunter 30T =
runs great - it idles perfectly at 900 rpm, when you push the throttle forward for more speed, it takes about 25% of the available space between the throttle and the binnacle to engage additional rpms - so my max is about 2,000, when I believe it should be about 3,000 = I checked the idle screw and don't want to raise the idle rpms anymore than where it is,
is their an adjustment on the throttle arm, or in the binnacle, which I believe to be an Edson,
Many Thanks!!
Many Thanks!!
