A
Alex Pascu
IT happens when engine under load in gear, at around 2700 and up ,after 15-20 min. It goes down and up , but unless I lower the RPMthe situation worsen, sometines-not often- it shut off .No problem starting , anytime. It doesn't occur at lower RPM, about 2200-2500 even after an hour or so. I changed both fuel filters , but it didn't changed. I checked for air going in fuel supply , but it doesn't.The fuel is from trusty clean origin , allways checking it.No water in fuel . What can it be ? Anyone had similar occurance? The engine is on my 29.5 ,95' model' engine just 250 hours on it. will much appreciate some advise, Alex.
