John North
After running my engine at high revs 35000 + for more than an hour, I put my boat to bed. The next time I checked my oil, I saw a lot of oil in the pan under the engine. I had lost about 1/2 liter. I topped off the oil and restarted the engine and discovered that oil was running quite freely out of the gasket on the right hand side of the timing gear cover. Where is the oil coming from? Is there supposed to be oil behind the cover? Is the crankshaft seal shot? If so, how difficult is the job to replace the gasket or seal? I don't want to start taking the pulleys and belts off without some sense that I can do the job. I have worked on engines before, but not a diesel.Any advice? Do you have a diagram of the parts?
