Got the boat back in water with antifoul, prop speed and new cutlass bearing + 2 new stop cocks (ball valves) to replace ones on the kitchen sink and Macerator out thru hulls ( both were jammed open and the handles sheared of while trying to free them up
)While out of the water, I also cleaned out the cooling water strainer!
When leaving marina, the exhaust had that "different" sound and I got to the end of the channel into clear water as the over temp alarm sounded! Dropped the pick and pulled the input hose of the water pump - plenty water flow! Pulled off the water pump expecting to find a destroyed impellor but all good.
Greased up the impellor with vaseline and it turned easily with impellor blades folding in as expected! Popped it back on and pulled off pipe at heat exchanger - started it up and plenty of flow into under engine sump. Reconnect and take off pipe at rear of heat exchanger - still plenty of flow - reconnect everything and start up - exhaust sounded normal so proceeded off watching water temp gauge - steady at 75 Celsius.
Lesson, if you drain the cooling water while up on the hard, expect an air block and no cooling
