Same problem
My H30G with same engine spent the winter in the water on Lake Ontario, and when I took possession in April, it was very difficult to start. Symptoms were long cranking times, multiple restarts, a lot of smoke (both black and white smoke) and diesel fuel coming out the exhaust (very small quantity). Once the engine was warmed up, it ran fine. When the weather warmed up, the problem diminished, but the engine still smokes when first started. It does not smoke once warmed up. Also, the engine starts instantly if it's been run previously in the same day. I've measured boat speed versus RPM (using GPS for accuracy) and found that the engine seems to be putting out the rated horsepower. The boat makes 7 knots at 3250 RPM with the stock 15x12 2-blade prop. From reading posts on this site all summer, I've picked up the following tips: (1) don't crank for more than 30 seconds, and give it a rest between attempts, so the starter doesn't overheat; (2) if you're going to have to crank it for a while, don't open the sea water seacock. If you do, too much water can accumulate in the muffler, and cause back pressure on the exhaust or even back up water into the cyliners. Open the seacock as soon as the engine is running. I've looked in the Yanmar manual, and the 2GM20F does not have glow plugs. However, if you open the throttle all the way, the injector timing is supposed to be retarded to aid cold starting. One thing I'm going to try next spring is to crank the engine briefly with the compression levers open, then try to start it. This should get moving parts lubricated and maybe get some extra fuel into the cylinders. I have no idea if this will help --just grasping at straws. From many other posts and talking to a mechanic, there are hundreds of nasty things that can cause hard starting, from poor compression, bad injectors, cracked O-rings, bad fuel, etc., etc. I have removed the mixing elbow and found that it is clear, so that common diesel problem is not the problem here. If anyone has any suggestions, they would be appreciated.Bob England
