Yanmar 2gm20 circulation pump leak coolant
Tom u
May 3, 2015
5
Hunter 28.5 Athens
I have a Yanmar 20 GM in my Hunter 28.5 that is leaking coolant around the circulation pump pulley.
Seems really loose. Is this something that is a diy job or is it a serious repair. Any advice is appreciated.
Hunter 34 Alameda CA
Its not difficult. Better not use it any more until you fix it especially since its now loosey goosey. The easiest solution would be to just buy a complete new pump. You'll remove some hoses, the pulley and some bolts. Clean the gasket surface and reinstall. Top off the coolant and check for leaks.
Tom u
May 3, 2015
5
Hunter 28.5 Athens
Thanks Allan
Can you give advice on the parts I need and how the assemble comes apart. I'm pretty good mechanically but have not tackled this repair before
Oct 29, 2005
2,362
There was a discussion on raw cooling water pump here recently. Lots of info on rebuild of the pump.
Tom u
May 3, 2015
5
Hunter 28.5 Athens
The leak is around the top pulley (of the three), not the water pump pulley or raw water pump. Some of the Yanmars do not have this one- I believe it circulates the coolant. Is this seal replaceable or is it a pump in itself?
Oct 24, 2010
2,405
Hunter 30 Everett, WA
The top pulley is for the engine circulation pump. My manual calls it either a freshwater pump or an engine circulation pump (chapter 8) but interestingly it gives no details except for the rawwater pump. Having said that it isn't a complex device. Most DIYers should be able to rebuild or replace it. Rebuild should be cheaper, but take a bit more time.
If I were faced with this situation I would remove the old pump and disassemble it first then decide on rebuild vs replace. After having taken it apart you should have a greater idea of the complexity and condition of the pump. Then decide which course of action. It has to come off either way. If you replace it the only thing you are out is your time tearing it down, but then you will also know what's inside which is worth something in terms of education.
When I last rebuilt a Yanmar pump the rebuild parts were about 2/3 or so of the price of a new pump, but when it's done it is the equivalent of a new pump.
Ken
Thanks Allan
Tom,
Didn't mean to leave you hanging. We had a rather extended period of darkness out here, then I had to do some digging.
As you have mentioned then, it is your fresh water pump that is starting to fail. Mine did as well a number of years ago and once they get loose, rebuilding is usually not possible as housing wear can happen. Mine failed catastrophically at the absolute worst time as we were coming back from the Sacramento Delta and had just entered the SF bay with 25 knots of headwind and an ebb tide. The waves were 4 feet high and shaped like boxcars. I heard all this racket from the engine and the pulley was oscillating back and forth. There were ball bearings all over in the bilge. It took 7 hours to sail home instead of a 3 hour motor sail. Oh, and with the pounding the holding tank split from top to bottom. That took 3 months to deodorize.
I've attached a file from a Chilton's manual that describes the procedure for repair. Even they recommend complete replacement. You could try and rebuild yours as a spare, but amortized over the lifetime these things have, its pretty reasonable to just buy new. I have also attached the assembly drawing for the 3GMF motor pump. The pumps are the same for your 2GMF so you can refer to the part numbers there. I think you can find the replacement stuff at Kubota tractor supply outfits for a cost savings. You might consider pulling the thermostat as well (or at least buying a new one plus all the gaskets to keep in your spares kit).
Its not too bad of a job...4 bolts on the pulley, 3 bolts on the pump. You might have to burp it to get the air out of the pump. Just loosen something at the highest point and it should be fine.
Good luck.
Allan
10,104
Kind of a big job to rebuild.. Probably best to buy a new assembly and just change it. That said, to rebuild it, you'd need a press and the new bearings and mechanical seal. Bearings would be easy, but the seal is not sold as a regular Yanmar part. I am sure that it might be available from a pump rebuild shop, but that might be really tough to find.
The Yanmar part is 121000-42100.. there are a couple of Yanmar tractor places that would have the pump assembly too, but I think they are only about $20 less than the OEM part..
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
you are correct it is only about 20 dollars less surprisingly enough the fresh water pump is not that bad price wise ...i did have mine rebuilt by a shop in oregon for 80 dollars ...its best to replace it and have the old one rebuilt and keep it as a spare ...by the way the pump is made by AISE company in Japan if you can find a shop that rebuilds them that great
