Yanmar 2gm13 rpm question
2
2 8.0B Virginia
I am trying to figure out what my rpm operating range should be. Does anyone know of a link to the 2gm 13 specifications?
Thanks,
KH
Ross
Jun 15, 2004
14,693
Short answer is 1800 to 2700 RPM
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
You'll probably get lots of advice about operating your engine at 80% of its max rpms. But to me, I think the key is really finding your particular engine's "sweet spot." That is where you optimize speed, noise, vibration, and fuel usage. Motor out on a calm day with flat water, get up to 6 - 6.5 kts of boat speed, and tune in to what your engine is doing and telling you. My guess is that your optimum rpm range will be a couple hundred rpms on either side of what you were pulling that day.
Jan 13, 2009
394
J Boat 92 78 Sandusky
The 2GMF I have on my C&C 29-II has a max rpm of 3400 stamped on a plate on the engine. Cruising RPM as stated in earlier posts is a function of prop size, pitch, boat weight, wtted surface, and sea state. In flat water, I achieve hull speed (6.4) at 2600 rpm which is slightly below 80%. The engine seems very happy around 2400 rpm for long periods of time.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
GM Yanmars
I think that all the GM Yanmars are rated max hp at 3400 RPM. While many or most think that 80% is the proper way to run them, and I am not saying that they are wrong. But I have to agree about the "sweet spot" as mentioned in another post. My 3GM likes to run at around 24 to 2500. While that is a little below the 80% number, thats where everything seems to come together and it seems to run best at this RPM.
Ross
Jun 15, 2004
14,693
I like to run at about 75 percent of hull speed. Above that the horsepower/speed ratio goes very high.
