In response to Mike Swietzer:
I think the Yanmar !GM 10 is perfect for the Vega. It weighs only 170
lbs or so, is pretty small and has plenty of power to push the hull.
Maybe you could get a used 1GM and rebuild it. They look like a pretty
simple engine. It might cost alot less to rebuild a Yanmar than a BMW
engine.
I use a big 3 bladed prop - 10" pitch and 13" diameter. For me the
pitch is too much cause I got to hull speed at low RPM, then when I was
motoring into rough seas, the engine works too hard. Also the diameter
is too big. At 13" it comes within 1/2" of the hull and I understand
that that is too close. So I plan to get a 3-bladed 12" diameter, 9"
pitch prop. That will get my RPMs up and lessen any interference of the
hull with the water flow.
I plan to install a fresh water cooling system for the Yanmar. It costs
about $500.00. I just can't stand the thought of all that salt water in
the engine.
Has anybody else retro-fitted a freshwater cooling system on a Yanmar 1
GM10?
Does anybody know how to start a 1GM with the crank? The engine does
not seem to have enough inertia to keep going and start after I take the
crank off.
David Ham
Juneau, Alaska
engine.
the engine.
GM10?
crank off.
David Ham
Juneau, Alaska
