My 1gm tachometer is slow / sluggish to respond to throttle settings. Is it the tachometer which is 16 years old or the tachometer sensor/ sender?
While the tach on the 1GM is inaccurate, yours is wildly off, which suggest something is wrong with it. On both the 1GM in my boat as well as the spare sitting in my garage, the tach can be off by as much as ~250 rpm. The error is not consistent or linear across the rpm range. It is most accurate at the very low and high ends, with various amounts of error at different rpm in between. Wherever it is off it reads too low.Here is the print on how it works..Note that the tachometer instrument itself is notoriously inaccurate.. mine reads 2000 when the optical tach reads 2800. There are options available from a few instrument guys like VDO etc.. The ones that are usable are programmable to accept the output from the "tooth reader" on the flywheel.
