Ron Vanderveer
Gang(Warning: this one is kind of long! Sorry.)On a short cruise this weekend, I had an occasion to run the engine a good while and observe some weird engine RPM behavior that we had only suspected on our shorter trips. I know that several mentions of problems similar to mine have been posted, but I wanted to get another set of inputs before my co-owner and I start "working" (e.g swearing, sweating, crying) the problem. Here's the data:- 1982 Hunter 27, Yanmar 1GM diesel (7 HP) single cyl.- Three blade prop of unknown pitch and size (I know, I should have this stuff memorized!).- Since we have owned the boat (about 1.5 years) we have never gotten it to go above 3000 rpm under load (in our defense, we didn't know the top end of the engine for quite a while after we owned it! It is supposed to be 3400 RPM, right?)- Starts fine, generally runs fine, nothing extraordinary. It will go to about 2900 RPM max (won't go any more than than 3000)- Sunny, warm Florida day, calm inland waters, not much wind. Boat is loaded normally.- Once under way, under power only, for about a half an hour or so, with no notice or other indications as to why, the RPMs drop fairly quickly to about 2500 and stay there. The throttle lever has not moved, and moving it forward and/or backward (i.e. jiggling it) does not change the RPM.- I leave it alone at the new lower RPM. Still further along, the RPMs drop again to about 2000, and stay there. Again, no lever movement or any input from the cockpit.- After we passed under a bridge, I killed the engine and we sailed for about 1.5 hours until we got to the marina entrance. Started the engine again, no problems starting, and just for fun I put the hammer down. Interestingly, it goes right back up to 2900 RPM with no complaints. - The engine never back fires, coughs, or otherwise gives signs of misfiring (at least to non-engine experts). It never quits completely, and it always goes to idle and stays at idle just fine.So what do you all think might be going on? I have my suspicions, but I am going to withhold those so as not to taint the advice inputs. Thanks in advance.Ron Vanderveer and Tom Hrkach"Dolphin Dancer"
