YSM12
HiNoticed you comment. When you manualy (push the throttle arm on the engine) is the engine suppose to rev up higher RPM than it does normally from the cockpit. When I bought this thing, from the cockpit it would rev up to where I thought the engine was going to jump out of the boat. It sat awhile then has never been the same. Seems to me I should have more rpms also? I had the injectors cleaned and checked.
