Tom Wootton
Put my new/used (dealer claims less than 5 hours running time, and the motor looks brand new, but it's three years old and off warranty) Yamaha T9.9 electric start 4-stroke on the boat today, and had some problems with idling, stalling, and sputtery throttle response. The motor would run fine for a while, then it would start to sputter and slow down. Gunning the throttle would help most times, but it took several seconds for the motor to respond. Other times it would stall out, and could not immediately be restarted. I also had audible variations in RPM with the throttle in fixed position. I checked the plugs and they were black with soot. Soot on the plugs usually means too rich fuel mix or excessive idling, right? The dealer says the motor is still in break-in period, so I was careful to stay at half throttle or less. Since the motor has been sitting for a few years, I thought maybe some old gas had gummed up the carburetor, causing the erratic RPM's and the soot on the plugs. Is there a gas additive that will clean out gummy gas in the carb without taking it apart, and should I replace the plugs? Or am I barking up the wrong tree? PS: I plan to consult the dealer next week, but taking the motor back to the dealer will be highly impractical, since getting it onto the boat was a major PIA, and the marina is an hour away from the dealer. PPS: The reason the 3 year warranty is expired: the motor was briefly sold to someone else 3 yrs ago, who returned it to dealer after 2 outings because it was not a suitable trolling motor for a 225 HP equipped fishing boat; I bought it on consignment. It was a little more than half the price of a new one; a great deal, or so I thought.
