I recently gave up on a new Tohatsu 9.8 because of vibration issues and bought a 9.9 xtra long shaft thigh thrust yamaha.
very happy with the new outboard. I just had one small question I cant seem to get answered. It came with a 7 x12 inch propellar...roughly. I just finshed my break in on the motor and am noticing the rpms will not get any higher than 4500 rpm at full throttle. Manual says it should be at the high end of between 5000 and 6000.
Talked to the dealer and they said I wouldnt cause any damage to the motor running it at 4500.
Now every thing I have learned about props and pitchs from discus ions the rpms are indicating the motor is over propped and that is hard on the motor. I obviously dont run the boat at full throttle and I get roughly 5 knots at 3800 to 4000 rpm. The motor is quite smooth and pretty quiet at that range.
Just wondering if anybody else with this motor has checked there rpm on their motors. If running a motor that is over propped is hard on it. Is it hard on it only when at full throttle? or at all rpm ranges?
I can step down to a 5 pitch prop but it is 150.00. It is not very common and not many people buy it. I dont think it would get me in the high end of the rpm range any way.
My other thing is the manual covers all motors that are high thrust xtra long shafts to short shaft non thrust motors. It would seem to me difficult to compare rpm ranges between a small inflatable dingy with a short shaft at full throttle and slow moving displacement hull.
Thanks
Dave
Thanks
Dave
