Yacht Specialties Steering
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Does anyone have an exploded view of the Yacht Specialties pedestal/steering system used on the 1980 Hunter 27? Any chance parts are available? I lost steering today while out in gusty winds, thankfully we were able to attach the emergency tiller in time to not run aground *pop. Back at the dock I didn't have time diagnose fully what had actually broken, but I did find that the cables are still connected at the quadrant. They had popped out of the channels in the quadrant and I was able to slip them back on but there is about 120 degrees of play in the wheel. I'd like to have some idea of what to look for before I get back down to the boat and start poking around. Hopefully my sailing season is not over :(. Thanks, Manny
K
karl.wilmot@gnb.ca
Steering Problem
Sorry to hear about your problem, but may have a solution for a broken part. A friend had a similar problem with no parts supplier, he took the broken part to a machine shop that was equipped with a flow jet water cutting device. They took the old parts measurements and programmed it into the flow jet which then cut the part from solid stock, then with a little machining and a new bushing he was back in business. Hope this works for you.
Manny
Oct 5, 2006
983
thank guys
The pictures help for sure, I'll check out the edson site steering tune up info. I'm hoping that when I get down to the boat on thursday I find that the cables were too loose and just popped out of place. I have a good machine shop near my home that have helped me get the old Renualt diesel running. I'm sure they can help with any broken parts with the steering mechanism. Machining something with a flowjet doesn't sound cheap... Grizz, how do you keep the area under the cockpit so clean???? Manny
Grizz
Jan 13, 2006
179
Hunter 28.5 Park Ridge, IL
PhotoShop
I'd like to say it's Photshop, but it's probably the result of camera flash. Plenty to clean above decks, so crawling around in cramped quarters isn't on the 'To Do' list. Good luck with your tune up. Season's over in this neck of the Great Lakes. Oh well...
Manny
Oct 5, 2006
983
Emergency tiller
Grizz, thanks for the "props" on using the emergency tiller. My friend that was with us was steering the boat and we we getting close to shore and were down to 23 ft of water so I wanted to tack. I asked if I could take the wheel and my friend slid over and I grabbed it. It spun freely. I thought for a moment - boy, thats very light pressure on the wheel, sail trim must be excellent - then I looked down at the rear lazarette where you can see the rudder shaft and it was not moving. I let loose a few expletives and mumbled something about a problem. That definitely got my friend's and my wife's attention. I then mumbled we had no steering. In what seemed like an eternity I got the rear lazarette unlatched and opened and pulled out the emergency tiller but could not attach it to the rudder. It was too tight. My friend had to stamp down on it with his foot while I held it in place and it finally engaged enough to be functional. I then jumped over to the outboard and started it just in case. I finally tacked the boat. All of this must have happened in less than thirty seconds because the river we sail on shallows up very, very fast toward the shore and we were clipping along at a good pace. We were down to about 10 ft of water at the start of the tack. After a couple of minutes I looked at my friend and my wife and I said that I still wanted to sail. We reefed the sails in a bit and ended up having a nice 11 mile cruise. I never quite got used to the tiller and it was a real workout. It has hardly any leverage at all. It's really impressive the forces on a rudder. Docking was extremely difficult. It took me about 4 tries to get in due to the high winds. Backing the boat with the tiller was much more difficult than I had anticipated. Even though we were going very slowly in reverse the forces were much greater on the tiller. My wife had to provide extra muscle so it wouldn't get pulled out of my hands. I'm really glad I had people with me when it happened. I would have had a really hard time dealing with that by myself. BTW - Photoshop, flash - it sure looks much much cleaner than the bowels of my boat. I even tried cleaning in there last year, didn't make a bit of difference! Manny
Jun 21, 2007
2,118
Yacht Specialties - I took Mine Apart
Dear Manny: Congrats to you and crew for getting your boat under control so quickly. I hope that I keep as clear a head when I encounter my first unexpected equipment failure. (See my final paragraph for more comment about the emergency tiller on my boat.) Back to your original post re the failed equipment, this past summer I completely removed and reinstalled the Yacht Specialties pedestal on my 1980 Cherubini 36. The steering mechanism was operating fine, but its removal was necessary to repair the cockpit sole's water saturated wood core through which the pedestal is fastened. By the picture that Ian McGain posted, the mechanism looks to be the same that is on my boat. As already posted by Grizz, although Yacht Specialities is defunct, Edson is a source of info. On the web page http://www.edsonmarine.com/support/techsupport.php you can find a pdf file entitled, ".... Planning Installation and Maintenance Guide." Its for their newer products, but it looks like many of the principles are similar to the Yacht Specialties system. Hopefully your cable just became loose over time and finally it slipped out the quadrant cable channels or off the sheaves that angle the cable from the pedestal to the quadrant. But if you do need to take your system apart here's some info about my experience: I did find it useful take close-up photos and make notes of each section before disassembly so that I would have better chance of later remembering how to put it back together. I can’t give you step-by-step guidelines, since I didn’t retain my notes or pictures. But how it fit back together is rather logical. Took a few hours to remove the system and reassembly took me a full afternoon. You probably will be dealing only the the cable/chain/sprocket system, but if the whole pedestal needs be removed, throttle and transmission cables need to be removed/re-attached from the engine side as well. (About a loose cable, before my cockpit sole repair, my cable was somewhat looser than I would have expected as normal ... "not to loose, not too tight". Perhaps this was because as the wood core rotted/delaminated between the upper and lower fiber-glass skin, the pedestal was depressed downward from normal which loosened the tension? My tip-off about the core damage was that the top of the pedestal/wheel assembly would move from side an inch or two when pushed ... it didn't feel solid.) One thing that I did do wrong on my first refitting of the steering cable is that I hadn't noticed that the cable crosses over itself inside the pedestal. That is: If you are standing to the aft of the pedestal looking forward, the chain/cable that drops from the starboard side of wheel chain sprocket crosses over to port sheave that angles the vertical drop of cable back to the quadrant. The other side crosses from port to the starboard sheave. Also although its not readily noticeable, one of sheaves is a bit forward of the other. This is so the cable sides don’t rub against each other as they cross inside the pedestal. This routing inside my boat was hard to see on my boat, but I probably would have missed the cross-over even if it was right in front of me. So best as you can, try to observe and record the routing from the chain sprocket to the sheaves and also the routing quadrant/attach points before you take the steering chain/cable off. If the cable doesn’t cross over itself inside the pedestal, the steering works, but turn the wheel to port and the boat goes right and vice-versa. While I was at it, another item that caught my attention was the molded plastic housing into which the gear shift and throttle handles are set. This is the piece that Ian McGain photographed and was unable to remove the four screws from. I had better luck as my screws came out. While I was researching Yacht Specialties pedestals in preparation for my disassembly project, I read somewhere (probably deep in this forum’s archives) that people have had problems with the plastic housing breaking inside where the shift and throttle lever shafts and cables are anchored to the housing. The accounts cite that if a cable anchor or throttle handle breaks free inside, one might not be able to (say) shift out of forward into reverse. Or the throttle might get stuck at full (or idle). Or the broken-loose part could jam in the steering chain. Any of which would be a heart stopper for sure if the failure occurred (say) after committing to the final turn into a berth. When I had my part removed from the pedestal, I did discover the beginnings of a stress crack near one of the cable anchor points. The web references said that this pedestal part is no longer available and a casting shop would have to custom-make a replacement. I decided instead to reinforce all the potentially suspect areas by encasing/epoxying them with custom bent u-channels I made from stainless steel sheet metal. Then I poured in lots of West Systems epoxy all around to ensure that nothing could possibly ever break apart. Back to your harrowing few moments after the steering failed, your narative rereinforced the wisdom of my decision after reinstalling the pedestal and steering system, to also check out that emergency tiller would function. But when I went to fit it to the rudder post, I found that there was absolutely no way to attach it ... zip, nada. On the boat, there was still the log book of a cruise to Mexico made in 1991. Off the coast of Ensinada, the steering failed and the owner had to be towed in. Repairs took a couple of weeks. (But probably the owner wasn't in a hurry anyway and Tequilla was cheap back then.) I expect that the Mexican yard never put in the fitting for the emergency tiller. Why the owner and subsequent owners never corrected is beyond be. I made a fix and the emergency tiller slips on to the post fine while the boat isn't moving. But your experience has prompted me to practice fitting the emergency tiller the next time I go out. I might find its not so easy when the rudder post is rotating back and forth due to waves and rolling motion pushing the rudder around. Better to discover now that maybe a modification should be made now than making discovery during a real emergency. regards, rardi
Manny
Oct 5, 2006
983
Great post Rardi
Thanks very much for taking the time to write your reply. There is some really great info on your post that I think would benefit anyone with a YS pedestal. It should be posted in the reference library. Do you have a picture of how your emergency tiller is attached? I'd be curious to see the differences. One thing I did notice which surprised me was when I was trying to attach the tiller, and the rudder was "free floating", it was basically tracking perfectly straight. It really was not moving at all. Granted there really isn't much chop where I sail but we definitely had a bit of a heel and winds were really gusty. I guess as long as the boat is moving forward the rudder will basically stay in place. Thanks again to all who replied. I'll update this on Thursday with my findings. Manny
Jun 21, 2007
2,118
Having Steering is Good
Manny: Good that the fix for you was straight forward. When you do go about attending to the steering cable (due to the few broken strands) I would be interested to know the process for getting it repaired. For instance, will you need to buy the chain/cable as one unit? Or can a local shop re-use the chain by swaging (or other method) new cable into your existing chain? regards, rardi
Jun 21, 2007
2,118
Jun 21, 2007
2,118
Jun 21, 2007
2,118
Manny
Oct 5, 2006
983
Rardi
I am wondering the same thing you are. I'm hoping the cables can just be swaged on to the chain. Maybe someone out there has done this before and can offer some advice? Manny
Manny
Oct 5, 2006
983
Rardi
Manny
Oct 5, 2006
983
Rardi
Manny
Oct 5, 2006
983
Rardi
