Don Alexander
Hi Bob,Great to have access to an expert.I use my autopilot (6000) for just about everything as I mostly sail single handed, and very good it is too. My last two autohelm pilots had a nuisance feature which the earlier ones did not suffer from.When lowering my mainsail I engage the pilot and motor slowly into wind . During this time I am on the coachroof and often the boat drifts off course by 10 degrees or more. Sometimes I hear the pilot bleep but mostly I do not.As the sail is being stowed the reduction in windage then means the boat responds to the hard over rudder and turns in a 360 degrees circle. It scares the hell out of me and all the nearby skippers. Also the sail blows everywhere just when I am trying to contain it.It would be much safer if the pilot attempted to resume the original course rather than leaving the rudder hard over.As an electronics engineer I can appreciate the problems of trying to drive a DC motor which is unable to turn, but this is NOT the case as the motor is turned off BEFORE the rudder end stop is reached. Why could the controller not make a try to correct the course once every 10 seconds or so as the previous (20 years ago) models did? I felt better able to trust them.Regards.
