Y25 weatherhelm
74
Yamaha 25 Hebe Heaven
It is more rigging/tuning issue.
The sails are ooooold, and the stays/shrouds are of some age but holding up well.
The genoa is 150% oversized. When I sail out alone, usually I just use the head sail, coz' it's handy with a furler.
Even with the head sail hoisted, there is already quite some weatherhelm under stronger wind. So I tried shorten the forestay by tightening the turn-buckle, and loosen the backstay in the same way. I also checked and re-adjusted the tensions of the shrouds accordingly.
The weatherhelm did improve a little bit (only!), but turned out that the upwind angle got worse. Anyway, I tried sail out again with both the genoa and main sail hoisted. The weatherhelm appears not much improvement.
Any idea on how to minimize the weatherhelm?
Thanks!
Boffin
Aug 30, 2010
81
yahama 25 Hong Kong
I t seem you need to reduce the sail area of the headsail when the wind goes up. With the main you can greatly improve the upwind angle . The boat works fine in 8-12knots wind , beyond that I need to trim down both.
jnovie
Jan 28, 2009
54
Yamaha 26 tall rig Marina Village Alameda, CA
Thanks!
I suggest you consider having a sail maker go out for a sail with you to help analyze your problem. Your old headsail may be too full and perhaps a re-cut will help flatten it. Adjusting your rigging will only help up to a point. You may be beyond that point with your old sails. Try sailing with just a 100% jib or even a 70% jib (if you have one) and a full main. Generally a flatter jib will allow you to point higher with less weather helm in heavy air conditions.
Sep 5, 2010
74
Thanks Boffin and jnovie. So I guess it's more on the aged sails with distorted shapes.
I agree that the headsail is large, I'll see when I can't stand it any longer to replace the sails, though there is no plan in the very near future yet.
