I sail only in the Atlantic where one can do overboard discharge. Existing system goes into holding tank only and head is used very little.. (Daysailer and grand-daughters.) No marina pump out available..
Current system (Jabsco) does not have a vented loop.
Plan I have is... cut 1.5 inch pipe. install 90 degrees fitting and go straight up. Install loop. Then on way back down, install Y valve. One to the tank and other to new Thur hull for overboard discharge.
Will this work??? Can I do the Thur hull above the water line or should it be below water line.
