Hi All,I thought I'd post a product review of the Xantrex XBM battery monitor. After years of guessing the state of charge and how long I should run my engine I decided to buy a Xantrex XBM battery monitor. This monitor was easy to install and is very easy to operate although set up was slightly confusing but I managed.The Xantrex Battery Monitor uses unique microprocessor technology to provide total battery status information for your battery bank. A simple display shows volts, amps, amp hours consumed, and operating time remaining. It also displays a "fuel guage" for your batteries. One fun feature is to set it to amp draw and see what different items draw per hour. I know my stereo and VHF combined draw about 4.5 ah, my chart plotter about .8ah and my anchor light 1 ah.If I have learned anything using the XBM it's that I now understand how a battery charges and how when it gets to 92% full it starts accepting very little amps from the alternator. The last 10% of charge can take upwards of 7 hours of running the engine to achieve a 100% charge. At 92% charge my batteries are accepting less than 5 amps per hour! At a 60% charge they accept about 45-50+ amps. The size of your alternator can do nothing to "force" current into the batteries if they won't accept it. If I draw my batteries down to 60% I can get back to 90% with my 90 amp alternator in about an hour but the last 10% takes a long, long time.In hind sight I wish I had bought the XBM before the bigger alternator because I could have saved a lot of money. I rarely, draw my two 4D battery bank below 70% and that's running a fridge, stereo, plotter, auto pilot and cabin lights at night. I now know that I really have no real need for a 90amp alternator and that the stock 51 amp alternator would have been fine.My advice to anyone planning an alternator upgrade would be to add a Xantrex XBM first and then decide if you need a bigger alternator. I actually physically swapped my 90 and my 51 amp alternators, mid summer, to see if there were any differences and guess what? It took the stock alternator, with built in regulator, about 15-18 minutes longer to reach a 90% charge from a 70% charge than with the 90 amp, externally regualted, alternator thats it! At a 90% charge the 51 amp alternator and the 90 amp alternator performed identically because the battereies were controling the rate of charge not the alternator or regulator. The other thing to note is that my 90 amp uses one of those fancy high dollar multi stage Balmar regulators. I now know that these regulators are mostly a bunch of BS as far as I'm concerned. The standard built in regulator on the stock alternator charged at the same rate at 90% and up as the expensive Balmar multi stage! I highly recommend the Xantrex XBM battery monitor and also Jack Rabbit Marine. I ordered my XBM from Jack Rabbit and it was on my door step the next day and I did not pay for next day Fed-X...The XBM is one of the most usefull devices on my boat!!
