Check it out.
Nov. 6, 2000Dear Nelson,Are you sure what your looking at is an Oceanis 320 and not either the F325 or Idylle 10.5? The reason I ask is because a check of the records with Beneteau reveals they were making on Oceanis 350, 390, 430 and 500 back in 1988, but I cannot find a record for an Oceanis 320. However, while I am a fan of Beneteau, I am not the absolute final expert on all of the models Beneteau makes or made, but Beneteau is, and I suggest that you call them at their customer service desk: ph.843-423-6459 and find out for yourself if the boat is being correctly described. If I’ve got it wrong I would really appreciate hearing back from you and I can add this information to my file.Obviously I cannot comment on the pros and cons of a boat unless I am certain that I have the right model. The other two boats I mention fit the time frame and here’s a quick description so you can compare it to what you are seeing and perhaps identify the boat yourself.To easily identify the F 325 you will find that the interior layout has a starboard quarter berth and the galley is on the port side and the head is also on the port side, aft of the galley. The Idylle 10.5 had the quarter berth on the port side and the galley was also on the port side forward in the saloon opposite the settee. The f325’s vital statistics included: loa: 32’5”, lwl 27’ 9” , beam 11’ 1/2” total sail area was about 624 sq ft. The Idylle was a bigger boat characterized by a longer cabin house and measured loa: 34.4’, lwl : 28.2’ ( note the relatively longer overhang), draft :4’8”.With respect to whether the boat your looking at is “ an offshore boat” is a different issue, and one that usually has less to do with the boat and more to do with the skill of the crew. My favorite example of this is Joshua Slocum and the Vessel “Spray”. Slocum rebuilt Spray from a beached derelict. It was an absolute dog to sail. This didn’t stop Slocum, a master mariner, from completing the world’s first known solo circumnavigation around the turn of the century. Maybe some marine historians can help us out, was it 1898 to 1903 that Slocum circumnavigated?I’d also like to refer you to another web site run by my friends Tom and Linda Waid, called “The Voyage of The Bellatrix”. They are returning to the states after doing a Caribbean cruise in their 28 foot Beneteau. They have equipped there boat well, they know how to maintain it, and they are both competent sailors. There are of course many other examples of remarkable voyages in small vessels: John Guzzwell’s circumnavigation in 21 foot Trekka, Tania Abei’s circumnavigation in a Contessa 26, a tribute to her considering the boat is small, wet and didn’t even have standing headroom. A real poor choice of a boat for a circumnavigation in my opinion, but once again it was the skill and determination of the sailor, not the boat, that made it happen.So to address your question whether the vessel your considering is an offshore boat more directly, is the boat your looking at well maintained? Do the systems work? Will they support your needs for weeks or months at sea? Do you know how to maintain them? Can you hand,splice and steer?Too often people put to sea with too little skill and too much boat. Were seeing that in the Baja HAHa rally where the boats are getting larger and better equipped and the sailors are getting less competent. A big boat is no substitute for sailing skill and a little boat is no deterrent to long distance voyaging. The Oceanis series is designed to go cruising, but is it an Oceanis that you are looking at? I hate to end on a generality like that, but if you can follow up on the boat make we can try to discuss the pros and cons of the particular model more thoroughly. I look forward to hearing back from you, and as poor an answer as it is, I hope it of some help to you.Brian Pickton @ BeneteauOwners.net,Aboard the Legend on a rainy day inRodney Bay, St. Lucia
