Hello all, I own a Hunter 23.5 with a Mercury 9.9 long shaft. I'm pretty sure the hull is rated for 6kts. The motor is about 2 years old, well maintained with moderate use. At about 3/4 throttle I will get about 6-7kts and when I go up to full throttle my speed really doesn't change much so I'm basically burning extra fuel for no good reason. I have the stock propeller. I am wondering if I change the propeller will that give me any extra speed with a full throttle. Or would a motor fin (I can't remember what their proper name is) be a better solution? Thanks for the help in advance.
