Worn detents on Tranny - MD2B
139
Nord Cantieri 38 St Marys
Hi guys,
I would like to get some advice on this issue. I have a 40 something year old Volvo MD2B that was "supposedly rebuilt" by a local shop in Jacksonville back in 2009. It has not seen much use since then. A few hours at best.
When I picked up the motor, the guy at the shop said that they didnt touch the gearbox, it was working fine when he tested it. I took it as is as he was right. It did work. But the detents were not the best then.
Yesterday, before starting her up, I could not tell if it was in gear or not due to the fact that the detents were almost non existant.
is there an easy fix to this issue or am I going to be stuck with having to have this gear box removed and rebuilt by another self proclaimed expert?
Thank you in advance,
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Hi guys,
When I picked up the motor, the guy at the shop said that they didn't touch the gearbox, it was working fine when he tested it. I took it as is as he was right. It did work. But the detents were not the best then.
not sure how yours is built but you may have a ball and spring in the shifter mechanism that has failed find you a detail of the gear box and study it to determine if what i described is indeed the way it is built and if so check that first.......
regards
woody
Mar 31, 2012
139
Thank you Woody,
I will be looking at that tomorrow. By the way, my first boat was an S2. I had a centercockpit ship. Really loved that lil ship. She was great for single handing.
