Wood Steps - Hunter 450 Passage
5
Hunter 450 Passage South Padre Island
Wondering how to care for the steps on our Hunter 450. The wood is in great shape but the finish has dulled. Any suggestions?
Rick D
Jun 14, 2008
7,206
If I recall correctly, your companionway steps look a lot like mine.
I used a polyurethane semi-gloss finish with a UV inhibitor. Specifically, Minwax Spar Urethane. Unfortunately, I can only get the water-based stuff locally now due to Air Quality Management District's regulation and it is not as durable.
Anyhow, the stuff is tough and easy to apply I get (got) about a year between coatings, and that's with heavy use. (Now six months with the water-based stuff.) Scuff it down with a 3-m pad or light sanding with 150 grit and vacuum or brush out all the debris from the grooves. I use several sizes of foam brush to apply. Between coatings, I clean it with a wood floor cleaner and keep it clean with a vacuum.
Oct 9, 2008
5
Thanks so much for the quick reply with what seems like great information. We will have those steps looking good as new in no time!
